Want a Winch?
Here’s your chance to win one
NEZR2 is raffling off a Smittybilt XRC-8 8k lbs.
$20 for a chance
Only 40 tickets will be sold
Drawing to be held on February 2nd, 2008
Need not be present to win
Click here for link to online sales.
The new Smittybilt XRC-8 Winch encompasses all the best features you would want in a winch. Every XRC-8 (8,000 LB.) winch features a 4.1HP Permanent Magnetic Motor and a Planetary Gear System with 265:1 gear ratio that will deliver power and reliability at a premium price. For a recovery system with the muscle and dependability to bail you out of any situation, the XRC-8 has all the heavy duty toughness you're looking for.
-Revolutionary planetary gear system boasts an 8,000 lb. line rating and 265:1 gear ratio
-4.1 hp, 12-volt, 24-volt permanent magnetic motor
-5/16" x 92' galvanized aircraft cable with replaceable hook included
-Intuitive design ensures a simple, hassle-free installation
-A heavy duty winching system with great features at an incredible overall value
-Drum size: Diameter/Length: 2.5" (63 mm) x 9' (228)
-Mounting bolt pattern: 10" x 4.5" (4 bolts, 3/8") (254 mm x 114.3 mm)
-Overall Dimension (LxWxH): 21" x 6.22" x 7.283" (558.8 mm x 158 mm x 185 mm)
