Pics needed for Cemetery Hill Gates
Postby Scott Hatch » Sun Mar 02, 2008 8:48 pm
Does anyone have pics of the gates at Cemetery Hill?
Please email them to me if you do shatch at nea4wd dot org
Postby tammylynn » Sun Mar 02, 2008 10:13 pm
I just asked Roy because he did the plans for those gates and he doesn't have those but said he thought there are pics of them on the website already. I'll try to look tomorrow if you don't get anything.
Postby Scott Hatch » Mon Mar 03, 2008 9:33 am
I do not think there is anything
Postby rblank » Mon Mar 03, 2008 10:23 am
How complex of a gate are you talking about? You can buy metal gates from Tractor Supply or any other farm supply type place (Agway, etc)
*DISCLAIMER* - The views expressed herein are the personal views of the author and do not in any way represent, nor imply to represent, the views of the North East Association of 4 Wheel Drive Clubs, it's officers, members, or affiliates.
rblank
Postby Scott Hatch » Mon Mar 03, 2008 10:44 am
We need to construct sturdy gates using the design from NH Trails Bureau with a box to protect the lock. These gates will be placed in very remote locations.
Have you seen the gates at Cemetery Hill?
Postby rblank » Mon Mar 03, 2008 11:15 am
Scott Hatch wrote:Have you seen the gates at Cemetery Hill?
DO you realize who you're talking to? :?
rblank
Postby Scott Hatch » Mon Mar 03, 2008 11:26 am
Have you seen the gates used by the NH Trails Bureau?
Its a 4x4 steel horizontal beam with U-Bolts used as hinges on one end and a hole for the locking shaft on the other. The cross beam has reflective tape on it.
The 2 posts are 8' long with 4' sunk into the ground and cemented. One has another u-bolt for the cross beam and the other has the lock box. The lock box is an backwards C for the cross beam to sit in with holes top and bottom to drop the lock shaft through. Under the C is a section of steel tube that contains the lock for the locking shaft. This box protects the lock from bolt cutters and firearms.
Postby Scott Hatch » Mon Mar 03, 2008 11:35 am
I'll get a pic today of the gate on the Hillsboro Rail Trail
Postby Paul » Mon Mar 03, 2008 11:38 am
I used to know the combo, but I don't have any pics.
They are nice gates.
Scott: I assume you have the specs?
Postby Scott Hatch » Mon Mar 03, 2008 11:50 am
YEs, we adjusted them a bit as we had some free I-beams we used for the posts but overall its the same
Postby rblank » Mon Mar 03, 2008 11:53 am
I've not seen that particular version, but I've similar around here used by DEM.
rblank
Postby Scott Hatch » Mon Mar 03, 2008 11:54 am
They were cheap and easy to build, the hardest part was digging the holes for the posts
Postby rblank » Mon Mar 03, 2008 12:42 pm
rent an auger
rblank
Postby Scott Hatch » Mon Mar 03, 2008 2:03 pm
rblank wrote:rent an auger
An auger doesn't work with rocks and boulders the size of a persons head, thats why it was difficult.
Postby tammylynn » Mon Mar 03, 2008 3:21 pm
Scott Hatch wrote:They were cheap and easy to build, the hardest part was digging the holes for the posts
:lol: :lol: I remember that.
I am sure when we need to build more you can use Roy again.
Postby Scott Hatch » Mon Mar 03, 2008 4:36 pm
Are you pimp'n out your husband? His assistance would be great :)
Postby Paul » Mon Mar 03, 2008 4:49 pm
Hey, I can weld too ya know. :welder:
Postby rblank » Mon Mar 03, 2008 5:05 pm
*wiping water off my computer screen*
rblank
Postby mika » Mon Mar 03, 2008 8:50 pm
Below is a typical pipe fence design used by the Federal BLM if anyone is interested.
mika
Postby tammylynn » Mon Mar 03, 2008 9:33 pm
Paul wrote:Hey, I can weld too ya know. :welder:
Do you work in a welding shop everyday where you have connections on getting the metal? :lol:
